Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - Bremslicht...?
Hallo Leute , ich hab wieder mal eine Frage an Euch und zwar steht die typisierung meiner Vespa PX125E am Mittwoch ins Haus - hab heute nochmal alles überprüft ob alles läuft dabei ist mir aufgefallen das bei der (Hand)bremse das Bremslicht nicht funktioniert - bei der Fussbremse hingegen schon , hab jetzt mal das Licht hinten demontiert und festgestellt das nur 1 Kabel zur Fassung hingeht - dann kann ja nur eins funktionieren oder seh ich das falsch ???
Würd mich über eine fachmännische antwort freun da ich da ja überhgaupt keinen Plan habe...
vorderbremslicht ab ca. scheibenbremsenmodell, wenn du eine verbaut hast, ists ganz easy einen schalter für bremslicht einzubaun und anzuhängen, ich habs jetzt auch bei meiner pv so gemacht.
