Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - Michelle Hunziker stürzt in "Wetten dass" mit der Vespa
Schon gesehen ?!!! Michelle Hunziker stürzt in "Wetten dass" mit der Vespa.
BILD-Bericht: Bei der Wette des rasenden Pizzabäckers kam die Schöne ins Straucheln. Mit einem Vespa-Motorroller begleitete Michelle den Südtiroler Pizzeria-Besitzer, der mit seinem Motorrad ein ganz andere Art Lieferdienst präsentierte. Im Fahren belegte und backte der „Wett“-Bewerber die Pizza, schnippelte Tomate-Mozzarella und goss den Rotwein ins Glas. Michelle drehte hinter ihm die Runden, rief ihm die verbleibende Zeit zu. Als die Wette endlich geschafft war, brauste die Moderatorin mit nassen Reifen zurück in die Halle – plötzlich rutschte das Hinterrad weg und Michelle Hunziker stürzte samt Roller. Sie stand sofort wieder auf ihren High Heels, winkte und sprintete Richtung Bühne, um gleichzeitig mit dem Pizzabäcker und seinen Teigfladen anzukommen. Er gewann die Wette, ihr ist nichts passiert!
_________________ Ciao Vespeblue
Zuletzt geändert von Vespeblue am 06.12.2009 - 21:30, insgesamt 1-mal geändert.
